Hi !
I own a Btwin forme 1 , the shifters are grip shifters Sram 3.0 comp and the rear derailleur is a Sram 3(1:1 actuation ration)
I plan to change the grips to trigger, following are the options :
1> Saw this deal, but the actuation ration varies in both
http://cgi.ebay.com/NEW-SRAM-TRX-7-SPD-TRIGGER-SHIFTER-X4-Rear-Derailleur-/330568388747.
Is this compatible with each other?
2. Another deal can I use these triggers with my current setup
http://www.jensonusa.com/store/product/SL400A10-Sram+Trx+Trigger+Shifter+Set.aspx
If someone could explain the actuation ratios , i would be grateful.
thks
thks
