Coke-a-Cola, amazing stuff.
Known for years that a really easy way to free off seized/sticking pistons in a car or motorbike engine that has been sat still for years is to pour Coke down the bores and let it sit overnight. Then turn the engine over and lo and behold, it sprays Coke out everywhere but free's off the pistons in the bores.
The reason this works is that Coke contains phosphoric acid, you know, the same stuff that dissolves your tooth enamel. It's enough that it can slightly dissolve and penetrate the seized area where the friction has welded the piston rings to the bore. It also dissolves rust, and attacks oxidation- it's excellent for cleaning alloys and for scouring rusty gas tanks.
Apparently.
