A Surprising Tech Choice
StuAff
Silencing his legs regularly
Portsmouth
It was announced back in September, I think the formal launch was at the Rouleur Classic today (I was there but left before the presentation), Gerard Vroomen was there as was a 3T Strada team bike. They'll make it work....or be switching frames for next year. With the various cassette options (including a 9-32) and chainring choices I doubt they'll have a problem getting a decent gearing range for most stages. A bit of adaptation for riders, and possibly some earplugs to deal with all the tut-tutting from armchair experts who forget it's not their bike....
StuAff
Portsmouth
The whole 'jump' thing is overstated. Most pro riders are running 11-28 for the majority of stages anyway, the days of 23 or 25 max are long gone. I did see an 11-28 cassette described as 'gappy' in ProCycling a few months back- writer would have been horrified by the 11-32 I run on the Litespeed, let alone the 11-40s at least a couple of people on here run. I don't find my cadence falling into some chasm, neither will the team. I'm pretty sure that if the Aqua Blue riders want tighter cassettes for certain stages they'll get them. The single ring (and presumably a clutch rear mech) will be an advantage for the cobbled classics, no risk of chain drop.
Cronorider
Wouldn't a classic place be the last place you would want to ride one of these? The same could be said for mountain stages. You need to be running a minimum of 52 on the front, 11 rear, to keep up on the flats and downs, and would require, given the large front ring, what, least a 38 to 40 on the rear to make it up some of the steeper than steep inclines? If they are running 11-28 with a 38 front, then with a 52 or 53 on the front they are going to need something really huge on the back to make it up some of these long climbs.
StuAff
Portsmouth
First off, as I mentioned earlier, 3T is offering 9-32 cassettes (at least as standard, sure the mechanics will be able to tweak them) with a choice of two gear spacings. https://www.bikerumor.com/2017/08/3...t-overdrive-cassettes-shift-approach-1x-road/ 10t will likely be an option as well from 3T. As they're using SRAM's XD driver body, the SRAM 10-42 cassette is another choice. Secondly, a classic would be exactly the right place for these. Narrow/wide rings and a clutch rear mech will pretty much eliminate the risk of chain drop. See http://www.bikeradar.com/gear/article/i-took-a-monstercross-bike-to-the-classics-49687/ and the video version..
And 1x drivetrains aren't new in the pro peloton anyway. Tony Martin did OK in the TdF TT this year…
Cronorider
Even with a 9 on the back, a pretty big front ring will still be necessary for top end speed, so, a pretty large climbing gear will be needed on the back. Will riders be willing to put up with the wide spaced gearing? We'll see if it catches on
