A Stuck Valve Cap
Dogtrousers
Kilometre nibbler
With a pair - or possibly two pairs - of pliers, I guess. I don't recall ever having had that problem.
figbat
Slippery scientist
I’m assuming it’s a Schräder (car type)? If so, and you decide to go at it with some pliers, it might be worth holding the valve body itself with something non-destructive to prevent it from twisting and possibly tearing the tube.
Gillstay
Or you can snip the end off and then put a little hole under the valve and pop a new Shrader
valve in, followed by a patch.
Ajax Bay
East Devon
Are those patches of rust (edit: next to the second use of 'valve')?
And @Wester was ahead of the curve with this question too (2 March 2020, 16 pages):
What are the chances of a cyclist contacting Coronavirus ? as it is a respiratory infection I guess and I am only guessing it must be slim as most cyclists are always blowing hard so you blow out any thing bad that you breathe in
classic33
Leg End Member
If you're using a pair of pliers on the valve body and cap, use a piece of old innertube on both.
They can reduce the amount of pressure applied to the valve body and cap in freeing them.
