a 'sticky' chain lube..?
John the Canuck
..a long way from somewhere called Home..
any recommendations..?
been using 'Weldtite Cycle Oil'...seems ok but is very thin
just 1 drop on each link pivot - but then has to stand on rags overnight as the oil drips off
cheers
NormanD
Lunatic Asylum Escapee
Put a drop on each link, leave a few minutes, then spin the crank a few times, then wipe off the excess with some rags until clean ... no need for dripping oil :smile:
ColinJ
Puzzle game procrastinator!
^ this. FWIW I use chainsaw oil which itself is quite thin, but I follow the religion of MICKLE and don't have any drippage :thumbsup:
I tried chainsaw oil and it was horrendously thick! It formed great gloopy strands across the cassette and rear mech as I turned the cranks to oil the rest of the chain. I could also feel extra drag in the transmission - ok, not a huge amount of drag, but lube is supposed to make it easier not harder! Once I had wiped off the excess oil, what was left picked up loads of grit over a couple of rides and made a nasty grinding paste. I won't be using chainsaw oil again, unless I buy a chainsaw! :laugh:
J
John the Canuck
^ this. ....................., but I follow the religion of MICKLE and don't have any drippage
thanks both ...read the MICKLE article - then done on 2 bikes .......... twice...:excl:
surprised [shocked] at amount of black crud on the rags till it ran 'clean'
the cranks 'did' seem to run smoother afterwards ..............:thumbsup:
john
PS.. a good tip was 'pulling forwards - wipe backwards' - no hassle
mrbikerboy73
Worthing, UK
The trouble with "sticky" chain lube is that everything sticks to your chain. Muc-Off wet lube is nasty stuff. It's a nightmare to clean your chain and cassette after a few applications. I've stopped using it.
