DaveReading
Don't suffer fools gladly (must try harder!)
- Reading, obvs
Even more off topic than my last post.
Operation Stroller went well (https://www.cyclechat.net/threads/12-inches.214750/) - three tubes replaced with sensible ones featuring angled valves so that my son and DIL have no excuse for not keeping them pumped up.
Problem is that one of the latches that allow the wheels to be removed came apart, and I can't think of a way to reassemble it. It's a spring-loaded plunger that engages in a groove on the axle.
In order to reassemble it, I need to compress a small spring (approx 5mm diameter x 17mm long) to about one-third of its length, but in such a way that the compression can be released to allow it to do its work once the latch is back together. Problem is that once the spring is in situ, it's completely inaccessible.
I can post photos and/or a sketch if the above isn't enough to visualise the setup, but if anyone has any bright ideas in the meantime they will be very welcome.
