A problem with my headset
Wester
II have a ridged mountain bike and I have a problem with the headset on it
It shakes from side to side when I am cycling and I have to keep both hands on the handle bars to steer it straight
What is the cause of this I guess that it has got something to do with the bearings in it
Sharky
Kent
Sounds like a loose headset. What type? Modern ahead system or the older quill type?
A photo if not sure.
  • Like
Reactions: C R
Wester
Wester
Loose headset, and or bearings have perished. You'll need headset tools for the quill stems - big spanners.
I have checked and it is not a loose headset so it must be the bearing are the problem . what size bearings do I need or are all bearings the same size ?
iluvmybike
Headset bearings vary - some are caged bearings (or even just loose ball bearings)of different sizes both in diameter and ball bearing size - some are cartridge bearings whoich again have different diameters, heights and angles. Until you take it apart and have a look you won't know and you need to ensure you replace like with like - unless fitting a whole new headset (that may required if it is badly corroded and from what you said it sounds awful!). This link explains it all : https://www.bikeradar.com/features/the-ultimate-guide-to-headsets/
  • Like
Reactions: C R
