LosingFocus
Lost it, got it again.
On my Virtuoso road bike I've currently got the the standard 700cx25 tyres that came on it. Im thinking about 2 different changes for different things and I was hoping for some expert knowledge from you fine people.
1) Thinner tyres: Assuming I can put on thinner tyres (and I will check the wheels later), is there anything else I need to look at or do; or is it just a simple "old ones off, new ones on" swap out?
2) Wider tyres: Assuming I can put wider tyres on (again, need to check), is there anything else I would need to check? One thing I can think of is the brake system, but even then Im not sure what I would need to check.
3) A change of wheel set. Now, assuming I can put thinner tyres on the bike, I would keep these on the rims and use them in good weather on nice roads. Seeing as I also want to use the bike in wet, windy conditions and also take it to some much less smooth roads (planning to take the bike to Cornwall where I will be on some lanes and paths), would it be possible for me to buy a set of 2 new rims and the appropriate cassette to match my current one, put some nice wide, knobblier tyres on and simply swap the entire wheel set over as and when I wanted?
