This is a 60cm 1980s type bike, 10 speed....a blue Falcon (will get photos up soon). Downtube shifters.
1. Is it possible to make 7 speed sora STI shifters work for this bike keeping the gears I have?
2. What is the most effective way to remove frame stickers? The ones on my bike are pretty tatty.
3. This bike doesn't have rack fittings....but I have a rack I would like to put on! There are mudguard fittings on both the front and rear wheel which I can mount the bottom of the rack to. The rack has two retractable "arms" made of a sheet of metal with a hole at the ends...to be bolted onto mudguard fittings on the stays on a normal bike. I dont really want to drill holes in my stays as they are thin enough as it is....so has anybody seen a clever, and cheap, alternative to putting a rack on.
4. the wheels are slighlty out of true (when the brakes are set 3mm away from the rim, the wheel rubs as it rotates) ...... does this provide me with a health risk that the wheels may fail?
5. If I want to upgrade from the older 10spd groupset to a modern groupset...is this possible? ..will a modern BB fit in an old frame?
Thanks
Thanks
