Hi,
Here's a question that some of you may be able to answer.
I think my battery on my newish car to me is failing.
The symptoms are ,
it seems to me when starting the car it turns over slowly (it's always been like that since I've owned it now for 7 months)
Very occasionally it refuses to start first turn of the key but it always starts on the second attempt.
Today again it cranked over slowly and it then stopped cranking, Second attempt it started but I noticed the clock and date in the dash had reset itself and needed resetting again.
I checked the battery and the voltage was good 12.7 but the amperes under load was reading 225 and the battery is rated at 550.
The car had covered barely 1500 miles each year from new and is 21 year's old.
This is definitely not good thing for keeping it's battery or batteries it's had throughout it's life in good health ( I now regularly use it for a 30 mile commute each working day)
Would a battery that's got a low cold start amperage cause weird things to happen such as resetting it's time and date display on the dash.
Either way I've bought a new battery today as I didn't cherish the thought of getting stranded in the middle of nowhere.
Another thing I noticed too was that the old battery was the wrong size.
It was about 20 mm smaller than the correct replacement in height and length.
All the very best to you all,
Johnny
The symptoms are ,
Johnny
