If anyone else dislikes the feeling of stickiness that tends to manifest itself on rubber brake/brifter hoods after a while.....
I have found that a clean up with silicon lubricant does the trick. Spray some onto a cloth (to avoid contaminating brake discs/rims when spraying it onto hoods directly) and then give them a good clean. Use a white cloth if you want to see how much filth comes off (from even supposedly clean hoods after a normal soap and water wash).
Both WD40 and 3-in-1 do a good silicone lubricant. NB.... normal WD40/GT85 etc. does NOT work for this!
