lulubel
- Malaga, Spain
These probably seem quite simple to most people, but here goes ....
I have a road bike with a triple chainset and a 9-sp cassette.
1. I'm getting a bit of a "rattling" noise from the chain when I'm using the middle chain ring and the top end of the cassette. The chain isn't slipping, and it isn't rubbing on the cage. I keep it clean and lubricated. The rear derailleur hasn't been knocked, and I can't see any sign of the chain trying to move to another sprocket. It doesn't happen when I'm on the big ring, so I'm guessing the chain may have stretched a bit.
How can I find out if it's stretched and is now too long?
The chain is about 3000/4000 miles old. Is it likely that it needs replacing?
I know I'd need to buy a chain tool to make any adjustments/replace the chain. Once I've bought one (which I'm quite happy to do), is it a fairly simple process?
If I need to buy a new chain, how do I know what to buy?
If I replace the chain, do I need to replace anything else at the same time?
2. I'm getting a very slight creaking noise that sounds like it's coming from the headset when I turn the bike away from the wall to wheel it out of the garage. It happens when I turn the bars to the left and further than I would when I'm riding it. It's a very faint noise, and it always happens at exactly the same point, and only when I turn the bars to the left. Could it be a sign of a worn headset/lack of lubrication/nothing to worry about?
If the headset needs maintenance, is this something I can do myself with limited mechanical knowledge (see chain question above
3. I'd like to experiment with lowering the front end of my bike a bit. I have 3 spacers under the bars, and I know I can take the bars off, remove a spacer, and then put it back on top of the bars (which will give me a weird looking sticky up bit, but is better than cutting the top off and then deciding I want to go back to how I was!)
Is this simple? Which bit do I need to undo? Is it the allen key bolt right on the top?
How much difference will lowering the bars by about 1cm make to the feel of riding the bike?
I also have another question about shorts, but that's a product question, so I'll stick it in the relevant place!
Thanks
)?3. I'd like to experiment with lowering the front end of my bike a bit. I have 3 spacers under the bars, and I know I can take the bars off, remove a spacer, and then put it back on top of the bars (which will give me a weird looking sticky up bit, but is better than cutting the top off and then deciding I want to go back to how I was!)
Thanks
