Psycolist
NINJA BYKALIST
- North Essex
I believe in maintenance being done in little and often sessions.  Every week, regardless of mileage done I go over both my bikes checking brakes, tyre pressures, lubrication and dirt. As a rule it only takes about 10 mins, unless I've been out in the wilderness on my MTB, but then I would have spent the time to clean up and check over the bike after that ride anyway.  Anyhoo, getting back to the point, I was going over my hybrid today, the first time for 3 weeks, because I have been re-spraying and re-building my MTB. So, about 3 times longer than the usual check up, and probably twice the usual weekly mileage over that period because of the MTB being out of commission, to find that one of the rim brake blocks on the front wheel was so loose, it had taken up a vertical position instead of the normal horizontal  If I had ridden the bike like that and used that front brake, and had the pad would  pressed against the tyre, and if it was a 'hard ' stop it could well have locked up the front wheel and sent me over the handlebars. I think its quite possible that the block had been moved into this position while I was wiping the dirt and grime away from the forks and brake, but it would have had to be loose enough for a cloth to move it. I had not noticed anything different or had any concerns that the brakes were not working just as they should. As my daily commute includes several steep hills, all be it very short steep hills, I think I am very lucky to have noticed this issue when I did. Its a puzzle to me how the pad was left this loose, or how long it had been like it. The last time I can remember having to re-seat the pad was before Christmas. But a close escape, and am I pleased that I do things in my little and often way.  Any one out there had any similar close shaves ?  in respect of mechanicals, rather than other drivers or road conditions, especially on a bike that you look after and service yourself.
