Smokin Joe said:The rate of chain wear is just the same, the sprockets are exactly the same as 9-speed, it is only the spacing that is different.
Chains don't stretch because the sideplates wear, it is because the pins do on the inside of the rollers. It is the same with breakages, the thickness of the plate doesn't matter provided the plate isn't bent or the hole enlarged by careless fitting.Chris James said:And to account for the difference in spacing I believe the side plates are narrower on 10 speed so the same force is concentrated on a smaller area, increasing the wear rate.
Having said that, I haven't had a particular problem with my 10 speed chain.
itisaboutthebike said:10 speed was(is) a marketing ploy by Shimano and Campg to get us to spend more money on upgrading our current set-ups.
dudi said:dont ye be fooled by the suffolk countryside. there's many a short sharp hill round 'ere boy. let me be tellin ya!
but you're right. can do the same route on the fixie quite nicely.
