erudite
- Stoke/Birmingham
Hi,
I am about to set off on a tour from Santander to Roscoff in a couple of weeks and have a problem with my gearing. My shifters and front derailleur are 9 speed and my rear cassette is 10 speed. Would it be possible to adjust the gearing so that only 9 speeds are used on the rear cassette? As at the moment, when changing gear, the rear derailleur is missing out gears and i am also having trouble aligning the front derailleur with the chain (at the moment it is grinding against the chain when on the top ring).
Also, there is a slight play in the bottom bracket (probably about 1-2mm of play), should i replace this now? I was thinking of taking a spare with me and if things did get worse, I could replace it on the road.
Any advice appreciated
