I am 99.9% sure that I will be ok, but I just wanted to check with you all.
I have a ropey front Shimano LX trigger shifter on my old Trek that I use as a commuter. It is a triple with 8 speed cassette. I need to replace the shifter and have found the following http://www.chainreactioncycles.com/shimano-deore-m530-9-speed-tripletrigger-shifter/rp-prod87287
This is described as a 9 speed front shifter. I was under the impression that there should be no difference on a front shifter between 8 and 9 speed. Am I right?
