ushills
Today I learnt something new, a 10 speed 105 front dérailleur is not particularly compatible with an 8 speed set up.
While I have replaced my rear dérailleur twice now with 10 speed types, tiagra then 105 and not had a problem, following the great Sheldon Brown's (deceased) advice. I mistakenly thought and read that the same applied to the front dérailleur.
Well it's been fitted and it is very difficult to avoid chain rub, I can set it to avoid rub in the top and bottom extremes then it is difficult to find a position with the brifter where it doesn't rub in the middle of the cassette. Adjust the barrel adjuster to remove the rubbing, then it rubs at the extremes. What a pain.
Not surprising as the cage width on the 105 is 11mm and the 8 speed sora that came of over 16mm.
Not sure what to do now, I think 8 speed Claris is the only 8 speed Shimano now make.
