8 speed cassette with 7 speed shifters
London
I have heard (or imagined/dreamt/been sniffing too much GT85?) rumblings that Shimano indexed flat bar shifters actually have an extra click, so that a 7 speed shifter would actually shift an 8 speed cassette as long as you adjust the limit screw?
Any truth in this?
Reason I ask is I have an old 7 speed 1997 vintage hybrid/part-time tourer with combined shifters/canti brake levers.
I'm perfectly happy with the cantis and I like the levers, even though they were maybe pretty low-end in their time - the levers on my posh new tourer look cheapish/too shiny in comparison with their nice smooth/aged patina.
So if this could be done it would reduce fettling, all could stay the same and I could use a cassette with a bigger rear cog for getting up hills fully loaded.
I should stress that I have recently changed the rear mech to a modern one and it can definitely handle the extra chain length I'd need.
mcshroom
Bionic Subsonic
I don't know if there's any truth to the rumour or not, but you can get pretty low gears on a 7sp
http://www.chainreactioncycles.com/Models.aspx?ModelID=6387
Don't know about the extra click, but 7 speed shifters work well with a 8 speed cassette, with the 8th sprocket removed. The recommended spacing is 3.1mm. 8 speed is 3mm. I run two 7 speed bikes using 8 speed spacers - no issues.
cyberknight
Indeed, my current hack runs this set up with no problems using the same cassette set up with an 8 speed shifter with the limit screws stopping the fastest extra gear, i figured it was safer to have the chain fall off on the chain stay rather than the spokes if this failed although the limit screws hold it in so far........
Blue Hills
London
I know that cassette - it's good - have used it including on a 21 Dahon Speed Pro, but due to an oddity with my frame the small 12 tooth ring seems to end up with a bit of chain clash with the frame - not an issue if I have a chain on an 11 tooth small cog.
As for the other suggestions I suppose I could do that (stick to 7 speed shifters with 8-speed cassette) but I've pretty much decided to go to 8 speed [yes I know, I'm just a slave to fashion :smile: ] and I don't really want to lose the "fast" cog - just trying to do it in the simplest way. Also I like keeping as much of the original stuff as possible.
Am starting to get the idea that this extra click thing may be something of a myth.
Blue Hills
London
PS mcmushroom - how is egremont - I remember an ancient Mike Harding tape/record where he described it as the "gateway to oblivion" - probably just a throway line - trust you'll still give me helpful friendly advice - all the best.
Blue Hills
London
Ta cybernight but not sure I understand the problem - it's a 9-speed wheel build (damn the need for usseles dishing I don't need) - spacer on to allow 7 speed. So there will be no problem with 8?
cyberknight
because i missed that bit,ignore me:shy:
Blue Hills
London
no probs cybernight - I sometimes read things too quickly.
and I've just been told elsewhere that the extra click thing isn't true - I thought I'd heard it before but I have also misunderstood something more recently.
getting hot out there isn't it :smile:
