ChrisEyles
- Devon
I have a 73mm octalink BB that I'm wondering if I can use in a 68mm shell frame.
I'm thinking if I use a 2.5mm spacer on the drive side the chain line would be the same (might see if a cassette spacer will fit). The only disadvantage I can see is that there'd be 2.5mm less threads engaged on the drive side. The left hand cup bottoms out against the BB cartridge rather than the frame, so a spacer should be unnecessary on this side.
Does this sound sensible? Happy to buy a 68mm BB if necessary, but might as well use the one I've got if possible.
