bob smythe
Hello, I have had my specialized crosstrail now for just under 2 years, I recently started having problems. First the gear hanger that holds the derailleur on broke, which I thought was odd. My derailleur was a little twisted but the guy in the shop said it should be ok and fitted a new hanger. After a month I took it to another shop for the gears to be reset because they kept slipping. I thought it best to replace the derailleur with a new one as well, the one that was on before was an altus, the new one being Olivio, I was told the chain had stretched and that it would be better to change it so I had that done as well along with a new rear screw on sprockets.
Ok the problem I have is that I can not go into ratio 3:1 (largest front and back) the chain is too short and it ends up jamming. It does go into that gear but the chain is so tight it doesn't turn. I was told by the guy in the shop that this was normal and that when I was sold the bike I should have been told this, he said with the megarange 34t its very large with the unusually large front crank set.
Is this normal or is something not right. The problem I have is that I do a lot of night riding and tend to forget what ratio I am in, if I go into 3:1 and my chain locks out I could end up breaking it again. I hope this is understandable and that someone can advise.
thank you
thank you
