My wheelset has a free hub, so I guess it will not matter, good times!Don't think you need a shim. Do you have a freehub? Presumably you're not replacing like with like.
So I'm getting my first retro bike & I'm wondering if I can get a 7 speed cassette on my Ambrosio rims with zenith hubs built by the great Harry Rowland. Do You need a shim plate or something?
Regards.
Like this http://www.sjscycles.co.uk/wheels-m...te-on-8-speed-hub-body-spacer-each-prod18561/
However I don't think I can run an 11t with such a spacer so would I be best starting from 13t upwards??
Found this with grooves in so might be ok for any cassette.
http://www.chainreactioncycles.com/hope-7sp-spacer/rp-prod1289
So nice & easy into the vintage world. I may just add a campag groupset at a later date.The spacer goes to the back of the cassette, so it shouldn't affect allowable smallest sprocket size. For some systems (e.g. Campag) that limit is influenced by the lockring, but not modern Shimano/sram splined cassettes afaik. An old 7 speed wheel might have a freewheel rather than a cassette, freewheels usually (but not necessarily) have smallest sprockets larger than 11T.
As long as the dx100 shifters will let me I will.If your wheel has a free hub, why don't you go 8 speed, a much better choice of cassettes, my old 1988 raleigh went from 6 to 7 to 8 speed freewheel, to 8 speed cassette and now 10 speed, and from double to triple. The frame had a little tweek when it went from 6 to 7 speed, but from 7 to 10 speed no change. the 10 speed fits directly on the 8 speed freehub, and mine has 11t smallest, it doesn't look like there is enough clearance but there is plenty enough
fair point lolAs long as the dx100 shifters will let me I will.
