On an old-style 6-speed bike I've just replaced wheels, chainset, chain and block/freewheel. The problem I have now is that the rear derailleur won't engage the bottom gear - I've adjusted it as far as I can, but it's just outside of its range now.
Comparing the old and new wheels, I can see that the geometry is slightly different and the freewheel on the new one is closer in to the centre line of the bike.
A different derailleur with a greater adjustment range might do the trick, and the old one is getting a bit worn now and doesn't always engage as smoothly as it should. So I have been thinking about replacing it - I put a SunTour Vx on another bike and I really like that.
But my question is, can you get any kind of shims for old screw-on freewheels to adjust the positioning of the gear block?
Thanks in advance,
Alan
Thanks in advance,
Alan
), so I might replace it anyway.
