Quick question, could I fit a 5 speed freewheel onto the same hub, and would it work?
Paulus Started young, and still going. Location Barnet, 13 Oct 2015 #1 Quick question, could I fit a 5 speed freewheel onto the same hub, and would it work?
ANT 666 Trying to re member Location N.Wales 13 Oct 2015 #2 Yes if you are using a non indexed shifter.
midlife Legendary Member 13 Oct 2015 #3 Just make sure the mech is adjusted so it doesn't try and shif to the non existent cog Shaun
OP OP Paulus Started young, and still going. Location Barnet, 13 Oct 2015 #4 Cheers guys. It is on the old style friction shifters.
Apollonius Guru Location South Staffordshire 13 Oct 2015 #5 No problem at all then. You might have to set the H and L screws for the new block, but minor adjustment that.
