True, but by the time you had become a fit, strong racing cyclist, you would already have made up your mind what you needed, so you wouldn't need to ask!All depends on the cassette gearing. Seems like a good change to me. A fit strong racing cyclist could appreciate a triple in the mountains. Especially loaded for touring.
So how about a 52/40/30, I can spin out most of the 40 range given conditions, 52x13 I spin out down a small incline sometimes.For most people, a 39 is a better middle ring than a 42 because they can probably spend more time on it without having to go up or down a ring. Similarly, most people don't really need a ring bigger than a 50 because they are not fit enough to spin out a 50/12 gear (say).
(If you were very a fit, strong, racing cyclist then you wouldn't need a triple in the first place, and you wouldn't be asking the question!)
So - my vote is for the 50/39/30.
Oh, and the steps between the rings are more equal on the 50/39/30 (50 = 1.28 x 39; 39 = 1.30 x 30 whereas 52 = 1.24 x 42; 42 = 1.40 x 30)
I think the 40 would be more useful than a 42 for most people.So how about a 52/40/30, I can spin out most of the 40 range given conditions, 52x13 I spin out down a small incline sometimes.
I rearranged me rear cassette last week for a 18-20% climb i as going to do, not very long but steep for me, it was a standed 13-15-17-19-21-23-26 but changed the 23-26 to a 24-28, I have found may cadence has risen, but that could be due to the amount i am doing at the moment, and also my avg speed (though only marginal), I have thought about a 39 replacement as my middle ring is due to be replaced, but would it be better to do that and bring the 28-24 back to the 26-23 is the dilemma, I am still trying to safe for an 8sp shifter that would help, I do feel however on the whole it may be to low for general riding.I think the 40 would be more useful than a 42 for most people.
The top gear on my Basso is currently a 52/14. That is high enough for my purposes on the flat. I can pedal that up to about 35 mph on descents, but I usually just get my head down and freewheel if I want to go fast.
When I had a 42 middle ring, I found that I was having to drop down to the granny ring more often. With a 39, I can get up steeper slopes before having to do that.
