48cm road bars
BigD
Regular
Hello to all . I have just had a bike fit and I am looking for some 48cm road bars . can anyone help me out I cant find any . 46cm appears to be the max.
U
User6179
You will need to know the size of the clamp on your stem , usually either 31.8 or 26mm.
U
User6179
46cm bars will measure around 48cm on the outside as the sizing is done centre tube to centre tube btw
Citius
What reason did the fitter give for suggesting 48cm??
Presumably very broad shoulders? 48cm does sound huge, considering no one sells them as you say. Apparently Laurence Dallaglio uses a 46cm (having spoken once to an LBS that built him a bike) and he's a big chap
Ask your LBS to source you some from their supplier :smile:
Drago
Or get a Bike Fit one from someone who uses one of the alternative systems and recommends narrower bars.
In the same height to the cm, weight to the kg, and chest size to the inch as Dallaglio and do very nicely on 44s.
