42th Middle ring to 40th
You mean changing it to a 40. No but that isn't much of a change and you'll need a specific ramped middle ring or it won't work.
Nigelnaturist
Pontefract
Thanks for getting back.
Why wont it work with out a ramped middle ring, did triples and doubles in the past not have ramps, and I have run the same chainset with 30-38-48 without ramps on any of the rings, I mainly just wondered if the extra 2th jump from 40 to 52 would be a problem (guess I should have been clearer), I generally only ride on the middle and outer rings, and with upgrading the rear from 8 to 9sp, I was thinking because I will now have a lot closer grouping on the rear, by dropping a little on the front I could get better gear rangers, current 30-42-52 13/15/17/1921/23/25/28, but looking at 30-40-52 and 13/14/15/16/17/19/21 then either 23/26 or 24/28, depends what rear cogs I have that will fit.
The new cassette is an HG50 13/25.
Have you tried moving from the small to middle without a ramped middle, assuming that your chainset is currently ramped, not all are but the ring spaing is different.
You front derailleur will have a maximum tooth difference which should be specified on the tech. docs but it generally doesn't matter for a middle.
Nigelnaturist
Pontefract
I did when I first started, as I put a 38 and 48 on instead of the 42/52, it worked, I appreciate that the ramps help shift the chain up.
From the top of my head max difference is 22th.
It won't work so well. The changes would be a bit slower etc. It is up to you to decide how important that is.
It really would only be shifting from the small to the middle after a climb I couldn't do on the middle. which around here isn't very often, it depending on the rear but lets say 21/24/28 the only lower gears than the 40x28 would be the 30x24 and 28.
byegad
NE England
It will work without the ramps, but they make for slicker changes. My trikes have a mix of ramped and plain rings over greater ranges than yours, they all change satisfactorily. Changing from ramped to plain middle and outer rings on a 26 39 50 upgraded to 26 40 52 made not a jot of difference to changes on the road, although on the work stand the ramps did seem a lot slicker.
Nigelnaturist
Pontefract
Nope, my sirrus came like that I preferred it, its more usable; on very fast club runs I could spin fast in the middle ring, the 34 on a lot of compacts is too small for my liking and only good as a reserve for hills.
This is what my thinking is, and switching from 13/15/17/19 to 13/14/15/16/17/19 will make spinning in these gears a little better, with the better stepping, and with it only costing £25 from chainreations for chain and cassette its not to costly.
The spread makes sense, I changed mine for similar reason but unlike you lot I couldn't stop it dropping the chain going from middle to top and had to get a ramped middle.
Nigelnaturist
Pontefract
It did work, but i did only run it a while when I first started (June 2012) however the inner ring is a really odd B.C.D. and I wanted a lower ring than 30th so I ended up with a touring chainset on for a while (well about 10 months). So I suppose if I got an unramped one it would be a matter of test it and see.
The brifters have arrived not bad since I only won the auction Sat night. So hopefully stuff from chainreactions will arrive tomorrow.
