Longer makes it easier to secure the pump head imo
Yes if you’ve not got deep rimsThanks but would a 40mm valve be sufficient?
the standard wheels the bike came with. I have a BMC Team Machine SLR03
Not certain but the OE wheels seem to be RS010s which are not deep so 40s would be fine with room for the deepest pump head to fit on securely.Yes if you’ve not got deep rims
What’s on there at the moment? As above. If you’re fine with that, just get the same. You'll obviously need to remove the tyre and pull the valve out to check. Good to refit a tube and tyre at home at leisure rather than in anger by the side of the road in case you’ve got a super tight wheel rim tyre combo
And they’re ok to pump up. And aesthetically acceptable. Easy thenI've got 40mm on at the moment.
