3mm gear wire
Trax
Hi. Does anyone have a link to a seller of the very old style gear cable? The barrel end is 3mm diameter, and 3mm in length - much smaller than the standard barrel on modern bikes. Many thanks.
Ajax Bay
East Devon
Have just measured two, for interest, and they were (dia, length, all dims mm) 4.0 x 4.1 and 3.8 x 3.5. Is the 'socket' in the shifter it settles into the limiting factor and what could it cope with max?
Please don't take umbrage if I observe your title is misleading: gear cable has a diameter of 1.2mm and doubt that's changed much.
  • Like
Reactions: C R
T
Trax
Hi and thanks. The socket is the limiting factor and won't take the standard Shimano barrel, unfortunately. The bike is a ladies Peugeot road bike, probably 30 years old ,- possibly older. Regards.
Svendo
Walsden
Pedantry corner: some gear cable is 1.1mm, I think Sram and some coated types.
Actually possibly helpful corner: I got the wrong type of brake cable for the munchkins V-Brakes, but it was easy to file to fit especially as the button is pretty soft metal.
Ajax Bay
East Devon
I would be most reluctant to file any 'end button' on brake cables. You would not want your kin to be munched, still worse be the cause of it.
roley poley
leeds
yep have had to Dremel a few to fit too
