. I went with some flared compact kalloys for £12, that are now OOS.Thanks for the heads up, not sure I need anything else, will ask LBS to reuse the tape (otherwise I have some in waiting), the bike is fairly low mileage so cables good as well
I'm a bit OCD on bar tape, and depending on the type it doesn't always come off nicely or you get clean and dirty stipes if the overlap is different. But then I also find wrapping bar tape quite therapeutic.
Same with cables, whilst you have the bars stripped down, for the sake of a couple of quid each, if you are re-threading cables I would always use new (maybe reuse the old back brake snipped off on the front brake) as you often need to snip back to beyond where they were clamped to get a clean inner end to thread through the outer. Its false economy to reuse old ones, IMHO.
I’ll see what the mechanic says, he’s already rewrapped with the same tape.
Wiggle do have some nice new neon orange. I kept the pink as a thief deterrent as this bike is left locked up for 10 hours![]()
As the majority of bike thieves are male, as a thief deterrent, that is a brilliant idea!…… Just make your bike a bit more girly?👍😂
Is some fizik white tape any good? Yours for the cost of postage, it can be rewrapped as it’s not too sticky but it does get dirty easily.
https://www.fizik.com/uk_en/tempo-microtex-classic.html
How much posted![]()
Are you sure they’re 400 C-C as I seem to think Deda measured outside to outside?
