MacB
- Farnborough, Hampshire
Posting on CC and YACF for maximum exposure.
I'd like to build 2 bikes with 3 speed hub gears, basically I enjoy single speed but would like the option of overdrive either side if needed. I have been looking in to what's available and it's narrowed down to SRAM, I3 or T3, or Sturmey Archer, AW or SRF3. Price wise my preference is Sturmey Archer as they include shifters etc, I also like the gear range and shifter options better. The problems I run up against are twofold:-
1. dimensions - the dropouts I have are 126mm and 132mm - though SA show their hubs as having a 175mm axel & 126.8mm OLD option, this apparentkly isn't called for in Europe. All I can seem to find are hubs with an OLD of about 118mm and 165mm axels. Can these be used with spacers in the above frames or not? If not should I just try and buy from abroad, are spares interchangeable if need be etc?
2. where to buy - so far only found SJS Cycles and Freemancycles for SA stuff and Roman Road for SRAM.
Also how easy is the rear wheel removal with a Sturmey Archer setup?....thanks.....Al
