Sittingduck
- Somewhere flat
Scenario:
2 new tyres - Tubeless compatible but due to some issues I may run them initially with tubes. Tyres are Panracer Gravel King SK 622-40 (38mm actual width and broadly described as 700x38c). Tubes available are rated as 28-35... would the panel use these? My common sense tells me that if it rated to 35mm it will run ok at 38mm providing enough pressure, afterall we are only talking about a 1.5mm each side increase in tyre width. I am expecting most people to suck air through their teeth and say no way, get tubes rated to at least 38mm if not 40mm but curious as to the opinion of others and the assessment of risk...
Ta muchly
Ta muchly
