26" tyres for 26" wheels .. on not???
snapper_37
Barbara Woodhouse's Love Child
Wolves
Hi
Mate of mine at work got a bog standard MTB which he wanted to make a bit quicker for commuting. I advised to change the tyres to some slicks. The wheels/tyres already fitted were the usual 26". Found him a pair of Michellin, size 26" x 1 3/8 ". The diameter of these are too big and won't fit. Is this correct?
Any advice appreciated, thanks.
snapper_37
hubgearfreak
that's right. 590mm not 559 mm.
it's all here>>>>
http://www.sheldonbrown.com/tire-sizing.html
snapper_37
snapper_37
Wolves
Thanks hubgear. I'm even more confused now but thanks for the info! Can someone tell me what size tyre he would need then?
hubgearfreak
you've read the link? no:wacko:
your mtb wheels are 559mm diameter. any 559mm diameter tyres will fit.
snapper_37
snapper_37
Wolves
Yes I read the link Hub (well partially as I'm supposed to be working :smile:. So any 559s will do .... awww I get it now!
Thanks a lot for helping out :biggrin:
PS - thanks pinkypossum .....
simonali
With 26" it has to be a decimal size for MTBs e.g. 26x1.25. If it has a fraction e.g. 26x1¼ it'll be the old 26" size!
That's only a general guideline, but one that should work.
Herts
snapper
loads of good advice up there ^ but just one more ...
read the sidewall of the existing tyre - there should be 26" x ???? as well as 590 X ????? info . That should be the diameter you need..
Rhythm Thief
Ross on Wye
+1. I've fallen into the same trap, if it's any consolation.
snapper_37
snapper_37
Wolves
Sorted some out (Spech Nimbus) but now he's complaining they are *too expensive*
Jeez....
I can't be arsed!
