24/32/38 compact chainset required.
hank
Hi, I have a 1996(?) Claude Butler Enduro which I am restoring and it requires a new chainset. The front mech is fixed to the BB via a bracket, so cannot be raised, which is why I need a 24/32/38.
Can anyone help?
Thanks in advance, Matt.
RecordAceFromNew
Swinging Member
West London
These have the right rings but they were the subject of a recall, so I would keep well clear. Assuming you won't/can't just replace rings I would work from something like this by replacing the big ring if necessary, or change the (E type?) front mech. Don't forget you also need to know what bb you have and check if it gives the same chainline with new chainset before you buy or else new bb might also be needed.
hank
hank
Many thanks for your help. I'm awaitng delivery of a new chainset and bb.
