Scilly Suffolk
I've a Peugeot Carmargue (the racer and not the shopper, if you Google it) which, judging by the components, dates from the early Eighties.
I would like to replace the seatpost as it's a little short for me; if I could source one with an integrated clamp too, that would be great.
However, although the external diameter of the frame is 28.6mm it has been shimmed (in the factory) to 24.0mm and I cannot find any posts that size.
The shim looks to be held in place with some brazing along the top for about half it's circumference, so I could probably just file it off.
Any advice or suggestions.
Thanks.
Thanks.
