22t Chainring Diameter
Dogtrousers
Kilometre nibbler
Facetious answer: 22/pi teeth
Actually you may be able to get a decent estimate from that.
Tim Hall
Crawley
Teeth are on a 0.5 inch pitch, ie 0.5 inch between tooth tops. 22 teeth will have 22 gaps, giving a circumference of 22 x 0.5 = 11 inches. 25.4mm in one inch, so 11 x 25.4m circumference. Diameter = 11 x 25.4/pi = 88.9mm
(X post with Mr Trousers)
Outer, but I think Numbnuts has answered it.
classic33
Leg End Member
Should you feel like making one
  • Sprocket.pdf
