Nigel-YZ1
- Somewhere else... maybe soon.
I've restored and regreased my old Raleigh Merlin from around 1985 last year. Now it's going back into semi-active service again in a few months.
I noticed a little movement in the bottom bracket, and just put a little more turn on the shell which seemed to help. But when turning by hand there a little more resistance when the crank passes one spot.
I wasn't in the mood for a bearing change but just cleaned out everything and regreased, but now want to check things out more.
What's the most likely? The shells being worn or the axle?
If it's the shell I'll probably take it to Dave Marsh in Maltby and see about upgrade options, but if it's the axle I can try and source one myself and replace the bearings too.
