180mm rotor adapter
I am running a cheap set of basic spring forks temporarily but the posts on back only allow a 160mm disc, I want to run my old 180mm on front and told there is an adapter.
I looked at many of these but bit confused as to what will work ..
These are current forks I'm using as rockshox being serviced and re painted.
Ajax Bay
East Devon
That fork blade has post mount fitting so needs a 180 adaptor (to get from 140 to 180assuming it is designed for a 140 minimum).
