Currently have 11 - 27 but big run with serious climbs so thinking of going 12 - 30. Bike has SRAM force so will deraileur cope with this. I've also heard that shimano cassette with shimano chain better option than force ?
If it's a standard short cage force mech then you'll only be able to go to 28T. If you wanted a lower gear then you'd need to replace the mech to one with a longer cage, and probably need a new chain as well.
Do you have a standard double, compact or triple at the front?
Edit: my choice would be SRAM cassette with KMC chain but you can't go too far wrong with most SRAM Shimano combinations.
