111mm bb
PJ79LIZARD
WEST MIDLANDS
Does anyone know where you can get cheap 68mm shell, 111mm spindle length square taper bottom brackets from? All I keep finding are 110 or larger. Have they stopped making them?
110 would be fine.
Christopher
hi
Is it for a Campagnolo chainset? I think only Campag make 111mm BBs & the taper is different than Shimano pattern which uses a JIS taper (different than the Campag one). I cannot remember which way it goes but it is ~4mm difference, so a 111mm BB in one brand is equivalent to 115mm in the other.
That is the only difference though, you can happilly use a Campag crank on a Shimano BB or vice versa (I do on one of my bikes and it works just fine).
andrew_s
Gloucester
JIS square taper BBs generally come in 104/107/110/113/116/119/122
As above, 111 is Campag size and will be ISO taper, and mixing tapers makes about 4-5mm difference in the chainline.
If you want a 111mm ISO BB, Spa Cycles list a Neco BB, £25
RecordAceFromNew
Swinging Member
West London
Actually the Shimano BB in question is a 110.5mm unit, some shops call it 110mm, some 111mm. The model code is MM.
CRC has a UN54 in stock, only the UN26 is out of stock.
PJ79LIZARD
PJ79LIZARD
WEST MIDLANDS
What's the difference between the shimano UN25, UN26, UN53, UN54 and UN55, they all come in 68x110mm are they the same just varying in quality?
The item I was referring to as being out of stock at crc was the Chin Haur CH51 Square Taper Bottom Bracket 111mm.
biggs682
Northamptonshire
i went to local halfords to scrounge a box , only to find the bottom bracket i had been searching for in stock and on offer
What's the difference between the shimano UN25, UN26, UN53, UN54 and UN55, are they the same just varying in quality?.
Anyone? I'm pondering this same question myself now as I'm in the market for a 113 x 68mm BBm and while I know THIS one will fit for example, it would be nice to know the difference between them.
I read something about some having one plastic and one metal, one having two metal and one having a hollow axle, but I don't know if any of this is true?
