10 or 11 Speed Chainsets
grellboy
Apologies if this is an old subject, but what is the difference between a 10 and an 11 speed chainset? I'm having trouble working out how they can be different. Can a 10 speed chainset run efficiently with an 11 speed rear derailluer?
Levo-Lon
Yes ,they both work fine
Usually states suitable for 10-11 speed on the box as the set does both
It’s the distance between the rings that is the key. The 11 speed has a tighter gap, 11 speed chains are narrower across the rivets / rollers.
