So yesterday I took possession of a Raleigh Criterium frame/fork, and from turning the fork by hand it feels a lot like the headset is brinelled. A 32mm spanner is slightly too small, a 36mm is too big, the actual size is somewhere between the two and as far as I can measure it seems to be 1 3/8"
On a side note, the forks are chromed and rather pitted. I am mildly stunned by the efficacy of polishing them up with aluminium foil, but also very much aware that I probably haven't actually fixed the problems that will lead to further rust. Any tips on something I can seal them with?
- Is this a size I have any chance of getting a spanner for or should I just go out and buy a large adjustable spanner?
- having got it off, and supposing the headset needs replacement, does anyone know if I need the same size again or if the tube is a standard size that would take a regular headset?
- any other tips?
