I believe I have a one, as I took a 9 speed 105 triple off the OH's gravel bike and converted it to a 10 speed double. Will be the weekend before I can check the right shed at the right house to locate it though!
any joy. there's a couple on fleebay if not. thanks
Oh bollocks I forgot to look.
A
Found it if you aren't already sorted
52-42-30 170mm 9spd 105
Fc-5505
I believe that is for an Octalink bottom bracket whereas I have a hollowtech II unfortunately.
thank you so much for looking though
Ah yes its original hollowtech / octolink with the each side mounting to the BB spindle.
Hollowtech II has integrated axle I believe.
Back in the shed it goes unless anyone else wants it
I'll see if the octolink BB is in there whilst I'm at it, as i replaced it with a more modern 10spd CX double chainset, that probably was Hollowtech II.
Have you checked out Spacycles @Rooster1 ?
I recently fitted a 28t Spa inner ring, very similar to the Stronglight, works perfectly.
found the BB so available if anyone wants it £30 postedAh yes its original hollowtech / octolink with the each side mounting to the BB spindle.
